29 Users Online (28 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> How to switch off the value field from dimension.
Tue, May 20, 2008 at 5:00:31 AM | How to switch off the value field from dimension.
Rams
3 Stars: 3 Votes
I have to add some text to dimension and remove the value from it.
Text can be added using prefix or suffix option but the value can't be removed.
One option is to create the text with opaque background but is it possible to switch off the value field?
Now on the implementation stage....
Tue, May 20, 2008 at 10:01:05 AM | How to switch off the value field from dimension.
lunchtrayrider
3.5 Stars: 7 Votes
in 2008 you can't turn off the value. you can cover it up or make it really small by creating a new dimension style with really small text.
I like scooters. and motorcycles.
Tue, May 20, 2008 at 10:06:15 AM | How to switch off the value field from dimension.
rkitect
rkitect Avatar
4 Stars: 29 Votes
No... the purpose of revit is to be able to keep dimension annotations coordinated to the actual value of the dimension.  There is a family called "Fake Dimension" available either here or somewhere in the AUGI Revit posts.  You can use this to create a dimension that allows you to change the text.  The other option is to make a dimension style that is INCREDIBLY small and then place text on top of the value.
HTH!
Tue, May 20, 2008 at 10:08:49 AM | How to switch off the value field from dimension.
Rams
3 Stars: 3 Votes
Thnx for the help. I wish this could be possible in future version of revit.
Tue, May 20, 2008 at 2:43:29 PM | How to switch off the value field from dimension.
lunchtrayrider
3.5 Stars: 7 Votes
i believe you can substitute text for numbers in 2009.  someone here can confirm im sure.
Tue, May 20, 2008 at 3:20:05 PM | How to switch off the value field from dimension.
4 Stars: 203 Votes
No, you cannot change the value for text in RAC2009, this field stay not available to edit...
Wed, May 21, 2008 at 2:44:42 AM | How to switch off the value field from dimension.
Rams
3 Stars: 3 Votes
I agree with Typhoon. I have seen revit 9 twice but option is not available.
Does anybody know where to send these type of wish request to autodesk?
 Thnx
Wed, May 21, 2008 at 3:38:53 AM | How to switch off the value field from dimension.
4 Stars: 203 Votes
Try in "Autodesk.com - Support - Contact us", i guess....
Wed, May 21, 2008 at 1:19:20 PM | How to switch off the value field from dimension.
LIZARD2806
3.5 Stars: 7 Votes
Sorry to disagree, but I just went back to doublecheck and I can make dimensions in 2009 be replaced with text.  But perhaps I am misunderstanding.  What it does NOT allow you to do is to put a numerical value in the override box.  That was a good idea, as you get the best of both worlds....no lying about dimensions, but you can change a dimension to something like"varies".  See image.
**Using Revit Architecture 2009, 2011, and 2012**
Wed, May 21, 2008 at 1:26:58 PM | How to switch off the value field from dimension.
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
If you absolutely must override the dimension with a value (I do not recommend this), you can always put a period or something in the value string. (example - 10'-5".) By placing the non numerical symbol it reads the field as text.
Wed, May 21, 2008 at 1:56:38 PM | How to switch off the value field from dimension.
#11
4 Stars: 203 Votes
LIZAR was right, we can change the value by "Replace with text", sorry LIZAR...
Wed, Mar 13, 2013 at 3:21:51 PM | How to switch off the value field from dimension.
#12
muriloap
If really want to create a "fake" dimension with out any period or comma, here's a trick
After dimension is created, double click the value text, then
- Change to the value you want in the Replace With Text field
- And then, with the cursor still in the field, press Alt+0031 (press and hold Alt and type the numbers in the numeric keyboard wiht NumLock)
If  you want no text, just do Alt+0031, and nothing will be showed.
Best regards,
Murilo Andrade
Switch ID Grayed out in Revit MEP
Tue, Feb 26, 2013 at 11:33:36 AM
I can't assign a switch ID to a switch
Wed, Dec 9, 2020 at 5:42:46 PM
Dimension String
Wed, Nov 22, 2006 at 3:05:15 PM
DIMENSION TEXT
Tue, Jun 5, 2012 at 10:17:41 AM
Reference Plane Dimension
Sat, Aug 20, 2005 at 7:33:46 PM
Page generation time: 0.3395
