49 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Imported CAD drawings - editing in Revit
Fri, May 16, 2008 at 1:37:34 PM | Imported CAD drawings - editing in Revit
mteag
Revit v2009
I've got several CAD Drawings imported. I want to be able to edit the cad drawing and keep as much 3D info as possible. I don't have AutoCAD to open it up separately and edit.
Is there a way to change something from an imported CAD format to a Group, which I could then edit in the group editor?
I at least want the tags and their numbers to stay intact. Preferably the equipment blocks themselves stay intact.
I've tried partial explode and full explode. All I get is model lines on the same workset as what the imported CAD drawing was on.
The author of the cad drawing is working with me on this and has sent me two DWGs. On the first one when I exploded all that remained were the numbers from the equipment tags. Equipment blocks and tag borders disappeared. On the second DWG some of the blocks were intact, the equipment tag borders stayed as individual lines, and the tag numbers were gone.
Any ideas??
Sun, May 18, 2008 at 7:12:34 AM | Imported CAD drawings - editing in Revit
dexter303
Hi,
y
We had the same issuses at our company. DWG file that very just to difficult to handle.
So we send them to a comapany called astacus, that specialice in file convertion with manual labor.
In just 2days we had mulitply dwg drawings redrawn to Revit formats and to a low cost. ie 30dollars.
Very fast and very good. Now we only focus on the design and convert alla our DWG to rvt.
Check out http://www.astacus.se/english/index.html
Sun, May 18, 2008 at 7:45:39 AM | Imported CAD drawings - editing in Revit
4 Stars: 203 Votes
Hi, when you import files with CAD format they come just like a "Block", if you Partial or full explode this block, the components in 3D dissapear, Revit support ACIS objects just like NURBS, Extrusions, Revolves..., you can create an obj. in Autocad, Rhino, inventor, and so one, you can put the color and the material to those obj., before you render you can go to Settings-Materials and change the material(s) to that obj. or if you import an ACIS solid in a Mass family you can put "wall by face or Roof by face" in that, what i do in this case is if i can't do an obj. in revit because i spend to much time in that i go to Rhino, construct the obj., put the materials in that and then i import to Revit with LINK because if i need to change the form to this obj, i go again to Rhino, change them and go to Revit again and i have my obj. Re-New...
Edited on: Sun, May 18, 2008 at 12:06:10 PM
Delete old imported cad drawings
Fri, Jul 10, 2015 at 8:15:26 AM
Imported CAD formats appearing halftone
Thu, Oct 18, 2007 at 1:44:51 PM
Adjusting scale during import of CAD file
Tue, Nov 15, 2005 at 11:42:05 PM
Imported 2D Cad drawings > Rooms and Room tags possible?
Fri, Jul 1, 2011 at 1:07:43 PM
Link Cad Drawing Problem
Tue, Sep 20, 2011 at 7:22:01 PM
Page generation time: 4.1021
