66 Users Online (64 Members):
Forums >> Revit Building >> Technical Support >> Makeing Precast Panels
2 Posts No Rating |
Could someone please explain to make an exterior wall look like precast panels or give me a link to a walkthrough or tutorial? I've been trying to make one using a curtain wall. I can get the panel sizes to appear, but can't figure out how to make the panels have a precast material. Any help would be greatly appreciated.
![3.5 Stars: 3 Votes](/images/stars_3.5.gif) |
Go to your families and under Curtain Panels, pick the panel that you are using and go to properites. You can change the panel material to precast concrete panel. HTH
8 Posts No Rating |
I make concrete homes with individual panels and the disjoin command is the ultimate command. I use a shared parameter as well to help schedule the wall panels. Though on my drawings I only need to show the concrete, I find it difficult to add more materials to the wall like insulation or brick and still get a nice wrapping on the corners, So I usually make a working drawing and a Render drawing.
I don't understand why you are not using walls. Is the insulation and interior finsih added to the precast panels or part of it? I have also used walls for precast panels and used void vertical sweeps to cut the walls into panels.
Precast Concrete Panels |
Fri, Mar 31, 2017 at 12:28:39 PM
13
Placing window at intersection of 2 precast concrete panels |
Sat, Jan 5, 2008 at 7:57:00 AM
Precast insulated wall panels |
Wed, Oct 18, 2017 at 10:45:29 AM
Precast Panels |
Mon, Jan 7, 2008 at 3:39:27 PM
Precast panels and vertical reveals |
Thu, Jan 17, 2013 at 9:38:52 AM
Members: | 2016897 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
