Forums >> Revit Building >> Technical Support >> Controlling Yes/No Parameters with Formula
2 Posts No Rating |
I have a standard yes/no parameter for Visibilty of an item. I would like the Item to be visible, therefore "ticked", if the Base depth = 500mm, or 400mm, or 300mm, or 250mm but not ticked with any other Base depth dimension. I have tried all sort of formula but have failed so far. I cannot have the formula Base depth > 99mm as I will have dimensions in between the onse stated.
2 Posts No Rating |
Hi All,
Please ignore this as i have now suused it.............I simply created a interger parameter with the needed formula in it and then referenced the ye/no parameter to it's result............sorry for asking
Lee
6 Posts No Rating |
I am struggling with this and have not worked out how to set the Yes/No parameter with an If statement. I have tried IF(Integer=3,Yes,No) and variations with True, False 1,0 and with 'Yes', 'No' but without success Can anyone spell it out to me? thanks Andy Harle
Revit 2021 |
this is what revit help says about this, IF with Yes/No condition: =Length > 40 (Note that both the condition and the results are implied.)
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
6 Posts No Rating |
Thanks, I should have searched the Help, but i started on the Tutorials wher it doesn't mention the syntax Yes it does work =variable=3 - sets the yes/no variable to yes if variable=3
Revit 2021 |
Formula with YES/NO Parameters |
Tue, Jun 6, 2017 at 1:58:43 PM
Controlling Visiblilty Of Multiple Families |
Sun, Nov 4, 2012 at 10:16:49 AM
Enter formula anywhere a number is required |
Tue, May 8, 2012 at 10:57:13 AM
basic formula question regarding parameter use |
Wed, Jun 16, 2010 at 5:34:24 PM
Revit 2010 family parameters formula and room tag |
Fri, Aug 7, 2009 at 4:28:35 PM
Members: | 2114996 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
