161 Users Online (160 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Combined Electrical and Lighting Plan
Fri, May 16, 2008 at 9:11:00 AM | Combined Electrical and Lighting Plan
Tphill
Is there a way to show both electrical and lighting on one plan view? Underlay them? Curently i can not underlay my ceiling plan with my electrical plan. I'am trying to create a remodeling plan and want all the electrical items together.
 another question...  Is there to put the diameter symbol in text? And other speical symbols?
Tom Phillips
Architectural CAD Manager & Computer Admin.
Titan Construction & Engineering Services, Inc.
Mon, May 19, 2008 at 8:59:34 AM | Combined Electrical and Lighting Plan
To get special ASCII characters in REVIT just hold down the ALT key while typing the numeric code for the key from your keypad.  ie: degree º (ALT 167) diameter Ø (ALT 0216).
Mon, May 19, 2008 at 2:29:01 PM | Combined Electrical and Lighting Plan
marcpinard
We've had luck by starting with a Reflected Ceiling Plan and setting the Cut Plane in the View Range at 0'-0" (the floor level), and the View Depth at just above the ceiling plane.  This allows any outlets and switches, including outlets in the floor, to show.  You may need to also change some items in the plan to be hidden or transparent so you can see the items on the ceiling.
Electrical/Lighting plan [ 1 2 ]
Wed, May 13, 2009 at 11:27:52 PM
16
How to show lighting fixtures on floor plan
Mon, Nov 6, 2006 at 10:15:39 PM
Lighting Annotation Not Appearing
Tue, Nov 7, 2006 at 8:46:59 AM
Placing Exterior Light In Electrical Plan
Fri, Jul 28, 2017 at 8:00:29 AM
Lighting/Electrical plan
Mon, Dec 7, 2015 at 8:54:43 AM
Page generation time: 0.5819
