51 Users Online (50 Members):
Forums >> Revit Building >> Technical Support >> Uniformat
3 Posts No Rating |
Hi, I would like to add a uniformat code but can't find the way to do it ex: Windows : There is a code for aluminum , steel and wood windows . In many project either institutional or residential we use PVC windows how do I add the code. Rem
25 Posts No Rating |
In your revit program files you will find a .txt file called uniformatclassifications.txt Open it in notepad and edit...be careful to format the tabs etc correctly... you may need to restart revit to get it to read your changes...
3 Posts No Rating |
Thanks
Omniclass & UniFormat |
Thu, Oct 27, 2011 at 10:44:55 AM
Uniformat Assembly Codes: Revising |
Tue, Oct 7, 2008 at 3:52:19 PM
Uniformat assembly codes |
Thu, Jan 31, 2013 at 11:21:11 AM
about the uniformat codes |
Wed, Jan 28, 2009 at 6:17:09 AM
organizing components |
Wed, Feb 11, 2009 at 10:47:15 AM
Members: | 2022361 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
