19 Users Online (18 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Circular Beam
Wed, May 14, 2008 at 10:43:34 AM | Circular Beam
Rams
3 Stars: 3 Votes
HI,
Can anyone help me in placing a circular beam?
Find attached snapshot for required shape.
Thnx in advance..
Now on the implementation stage....
Wed, May 14, 2008 at 11:51:53 AM | Circular Beam
Looks like you already have it placed.... or are you really asking something else?
Thu, May 15, 2008 at 2:41:20 AM | Circular Beam
Rams
3 Stars: 3 Votes
The snapshot is taken from the pdf file. I have to put into my structural model. There is one option of putting beam on grid but its not taking circular grid
Thu, May 15, 2008 at 8:29:58 AM | Circular Beam
jmsfuentes
Could you not go to Modeling-Create-Structural Framing-Solid Form-Solid Sweep? I dont know about you..but some times this is faster for me.
Let me know if you have any questions..
Thu, May 15, 2008 at 8:34:38 AM | Circular Beam
Rams
3 Stars: 3 Votes
I want to place my parametric beam to the circular roof light. Solid modeling is last option for me.
Can you please give any more suggestions?
Thu, May 15, 2008 at 8:42:15 AM | Circular Beam
jmsfuentes
Ok..so let me get this straight..this is what you want?
Thu, May 15, 2008 at 8:50:37 AM | Circular Beam
Rams
3 Stars: 3 Votes
Yes i want the same
Thu, May 15, 2008 at 9:09:22 AM | Circular Beam
jmsfuentes
ok..its pretty simple. when you select the beam button under modelling...just select the arrow button on top. the "pick lines" button. Then it will follow whatever shape you select.
 Let me know if that works for you.
Thu, May 15, 2008 at 9:15:31 AM | Circular Beam
Rams
3 Stars: 3 Votes
Nope. I am getting beam button under structural tab and it doesnot allow me any pick button.
Thu, May 15, 2008 at 9:22:59 AM | Circular Beam
jmsfuentes
sorry..just realized you where using building and i am using structure. so you dont have this option up here??
Thu, May 15, 2008 at 9:29:59 AM | Circular Beam
#11
Rams
3 Stars: 3 Votes
Ya i am using revit architecture so not getting this option.
Beam description - SHS 150x150x6.
Thu, May 15, 2008 at 9:43:06 AM | Circular Beam
#12
jmsfuentes
Sorry..cant help you with building. But here is another way to work around it. If you have revit structure. You can do the beam there...import the structural model into your model, then do a copy monitor on it and then just remove the link. just a thought.
Thu, May 15, 2008 at 9:44:18 AM | Circular Beam
#13
JHanby
3.5 Stars: 3 Votes
Revit 9.1 doesn't have it.
Thu, May 15, 2008 at 12:40:24 PM | Circular Beam
#14
lunchtrayrider
3.5 Stars: 7 Votes
do an in-place family and categorize it as structural framing.  Unless you have revit structure.
I like scooters. and motorcycles.
Steel or concrete circular beams
Mon, Apr 20, 2009 at 3:56:25 PM
Circular Arch
Tue, Jul 21, 2015 at 9:06:16 AM
circular stairs
Mon, Mar 24, 2008 at 4:40:38 PM
Meeting Beam Systems to Glulam Beam
Wed, Jun 20, 2012 at 10:34:17 AM
circular pergola
Mon, Apr 29, 2013 at 10:40:28 AM
Page generation time: 0.2667
