Forums >> Revit Building >> Technical Support >> Scale 1"=100' - How do I get it to show
3 Posts No Rating |
I have been trying to edit my scale for views so that instead of 1:1200 - I will see 1"=100'
Go to view properties-->Change Scale?
Please explain further if i misunderstanding?
Hey, I work in a company where we print to paper size A1 and A3. Is there a way to create a viewport title where there are two scales? ie if the scale is 1:500, I need it to say 1:500 (A1) 1:1000 (A3). If the scale changes, I need to update the second scale ie 1:250, 1:500. I need it to show up like my picture (the viewport title is setup so instead of having a scale label, i wrote the scale annotation underneath). Thank you in advance for your help
- Core 2 Duo E8400 3ghz
- 756mb Nvidia 9600GSO 256bit
- 6gb Kingston RAM 800mz DDR2
- Windows XP Service Pack 3 32-bit
What do you do in CAD? - I doubt you do anything because I bet you scale the print - not the view! In REVIT, - you can do the same thing you did in CAD - you can set up duplicate views that are scaled correctly and placed on the correct sheets. VERY HARD to manage but your text will be sized so that you read it and you will be able to correct all of the text overlapping etc that happens when you re-scale the view.
41 Posts No Rating |
I have the same problem as Timbo (see his thread).
We set all our sheets up at A1 size, and print at 50% if we want it A3 size. We want to have an automatically updating field that calculates what that scale would be at A3 (ie: A1 scale x 2). Does anyone have any ideas as to how to do this? Im guessing I will need to set up a parameter in the titleblock family but my brain is too small to work out how to do it at present...
Thanks in advance!
Ollie
scale check |
Tue, Oct 23, 2012 at 5:05:09 AM
Scale bar on sheet onto to display at certain scale |
Wed, May 22, 2013 at 12:15:23 AM
changing scale |
Mon, Feb 14, 2011 at 6:58:20 AM
View Title scale text won't show |
Tue, Dec 29, 2009 at 2:36:52 PM
Can titleblock scale only reference one of many views on the sheet? |
Sun, Apr 14, 2013 at 10:46:47 PM
Members: | 2100741 | Objects: | 23171 | Forum Posts: | 152296 | Job Listings: | 3 |
