61 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> Tedious Family Parameter changes
19 Posts No Rating |
I have created many different families for the air terminals we commonly use on our jobs. Several of these families include up to 50 or 60 different family types. The problem I am having is that whenever I discover that I missed a certain parameter that needs to be associated, when i add the parameter I then must go thru EACH family type and enter the same info. Is there a way to change this kind of paramter all at once? I hope someone will tell me yes because changing adding and changing this data becomes extremely tedious and wastes a lot of time. Thanks again for any help. AVSteve
OK, I've done it again. A little more googling and I've found the answer. This example works for a parameter with a text format. I found that if I enter into the formula column "TITUS" (with quotes) that the word TITUS will then be propogated into all the different family types for that parameter. Then all I do is hit apply and then erase the formula hit apply again and all my types are updated. This is a huge time saver. I have not explored this technique exhaustively but I am sure it will be useful in other ways as well.
adding parameter sets in family editor |
Tue, Jul 13, 2010 at 9:43:40 AM
Add Family name to a shared parameter |
Tue, Jun 23, 2015 at 8:50:48 AM
<Family Type> parameter can't be controlled by formula. What else can we do? [ 1 2 ] |
Tue, Aug 27, 2013 at 3:53:53 AM
29
Family with coordinate parameter? - Revit 2010 |
Wed, May 12, 2010 at 3:45:58 AM
11
One family parameter has formula one has none |
Wed, Jun 25, 2014 at 1:05:54 PM
Members: | 2017191 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
