39 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit Structure 2009 printing
Tue, May 13, 2008 at 11:32:34 AM | Revit Structure 2009 printing
VANREVIT
VANREVIT Avatar
5 Stars: 2 Votes
Hello,
 I am hoping someone could help me out with printing. I manage to print a sheet (foundation plan) then I tried to print the roof framing plan and I had a message that shading was turned on. I turned that off then I tried to print once again and I keep getting the message " PRint Job could not be sent" can some one give me ideas as to why this is happening and how I could fix it? Cheers!
Vanrevit
Welcome to the REvitlution!!!
Tue, May 13, 2008 at 7:38:25 PM | Revit Structure 2009 printing
DESIGN4BUILDING
DESIGN4BUILDING Avatar
3.5 Stars: 3 Votes
i think i can help.  i use 2008, but it should be sim. i have 2009 trial but have not played with it.  when you create you sheet in a level or even 3d, once you finish placeing it, go to you file menu (upper left) drag down to publish 2d dwf...  once you get it in the dwf viewer you can print to adobe or just out of you printer.  tip  before you set your sheet, hide any thing you dont want on the print. like level lines ext.
Wed, May 14, 2008 at 11:25:59 AM | Revit Structure 2009 printing
VANREVIT
VANREVIT Avatar
5 Stars: 2 Votes
Thank you kindly
Rendering in Revit Structure 2009?
Sat, Dec 24, 2016 at 5:11:53 AM
SketchUp into Revit Structure 2009
Fri, Feb 27, 2009 at 9:51:24 AM
Revit 2009 Arch Struc User Guides/Tutorial Books pick up in LA
Wed, Feb 10, 2016 at 7:28:35 AM
Revist Structure 2009 - Where are Light Fixture families located???
Tue, Oct 21, 2008 at 2:54:02 PM
Revit 2009 : Coordination Between Revit Structure & Revit building
Fri, Jun 20, 2014 at 10:41:34 AM
Page generation time: 2.2204
