81 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> templates
Mon, May 12, 2008 at 5:55:29 PM | templates
ecocollaborative
is it possible to introduce a template into a drawing after a project is started?
Wed, May 14, 2008 at 4:33:49 AM | templates
Dafpfy
3.5 Stars: 11 Votes
copy everything into your new templatefile might work,
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Wed, May 14, 2008 at 10:12:00 AM | templates
callie
I haven't used this tool yet, so please try a test run before using it for real.  Under the File menu there is a tool called Transfer Project Standards.  I believe that you will open your template file and then open the file you want to transfer to.  In the file that you want to transfer to, choose this tool and it will ask you where you want to transfer from.  Choose your template and all of the information/standards should come in.  Good Luck!
Where have my templates gone in 2012
Sat, Apr 7, 2012 at 9:09:07 AM
Family Templates
Tue, Nov 26, 2013 at 9:56:22 AM
Drawing templates
Thu, Jun 10, 2004 at 1:41:37 PM
lineweight templates for optimal appearance
Tue, Jul 7, 2015 at 1:58:12 PM
Used based Revit templates
Fri, May 2, 2014 at 5:17:39 AM
Page generation time: 0.2165
