97 Users Online (96 Members):
Forums >> Revit Building >> Technical Support >> Cutting a Curtain Panel
41 Posts No Rating |
How do I get Revit to cut the last panel of a wall using a detail component or a complex extrusion ie: a 20" corrugated panel. I have gone as far as using a void extrusion to hide the remaining pattern and a shared parameter to track the lengths of the pieces, but this is extreemely inefficient because I have to edit the last panel in every wall unless I luckup and one works out. There must be a better way.
? ? ? Question needs clarity. Sketches ... ?
![coreed Avatar](user_avatar/14568.jpg)
also why are you providing a template file (.rte) ???
Cutting a complex Curtain Wall Panel |
Thu, Apr 17, 2014 at 9:44:49 AM
Curtain system panel problem |
Tue, Jul 10, 2007 at 10:08:07 AM
curtain panel offset |
Mon, Sep 1, 2014 at 4:30:14 PM
Curtain Wall Panel to Curtain Wall Door |
curtain wall panel losses end - edge |
Tue, Jul 15, 2014 at 7:04:22 PM
Members: | 2017035 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
