127 Users Online (126 Members):
Forums >> Revit Building >> Technical Support >> How do I render a walkthrough? I can't find any settings
7 Posts No Rating |
I have a walkthrough of a building I want to render but don't know what the first thing is to do. I have already rendered still images of the model, but I assume with a lot of time you can render each scene as it walks through. TThanks
Once you have your walkthrough as you want it, then go to file->export->Walkthrough, choose to render it here, and it should ask you which render settings to use... You said you already had some, so I assume you'd want to use those. Don't go anywhere until after it render's the first frame, because it then asks what format you want to save the walkthrough as... .avi, etc. Hope this helps.
Render a walkthrough? |
Thu, Oct 3, 2013 at 8:42:11 AM
New to revit and have a question... Re: walkthrough on 2011 |
Tue, Apr 12, 2011 at 6:01:12 PM
render specific frames of a walk through |
Fri, Oct 7, 2011 at 3:39:42 PM
Walkthrough on Render Setting Very Pixelated RVT '14 |
Wed, Oct 29, 2014 at 12:48:58 AM
Rendering a Walkthrough |
Fri, May 5, 2006 at 9:42:55 AM
Members: | 2030735 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
