Forums >> Revit Building >> Technical Support >> daylight portals
In Revit 2009, how do i turn on daylight portals?
nevermind i found it
where do u find it just let us know
Chirag C. Pawar Cad Solution Application Senior Engineer KLGSystel Ltd. India 301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel .: +91 22 409 16777. Extn. - 718Fax .: +91 22 275 76461.Mob .: +91 99 698 66851.Email.: chiragp@klgsystel.com Web .: www.klgsystel.com |
In the rendering dialog there is a pulldown for the QUALITY, set that to edit and in the RENDER QUALITY SETTINGS dialog check the boxes for the daylight portals you want Revit to read. You have three choices to pick: doors, windows and curtain walls. Just check those and Revit will do the rest. HTH
I should also mention that there is a pulldown on the top of the render quality dialog that you will need to set to custom to allow you to change the settings.
thanx 4 the reply brettgoodchild
Can you limit Daylight Portals? |
Mon, May 17, 2010 at 1:50:08 PM
Daylight Portals Rendering |
Mon, Jun 24, 2013 at 7:36:13 AM
Daylight Portals |
Tue, Jan 10, 2012 at 9:34:22 AM
daylight portals 0 |
Mon, Nov 25, 2013 at 11:59:52 PM
day light portals |
Tue, Aug 23, 2011 at 7:09:14 PM
Members: | 2103803 | Objects: | 23178 | Forum Posts: | 152298 | Job Listings: | 3 |
