160 Users Online (158 Members):
Forums >> Revit Building >> Technical Support >> underlay
6 Posts No Rating |
I am new to Revit, using 2008. I am currently having a problem with underlay where I cannot get the floor below (1st flr.) to show as an underlay in the roof plan. Also, when I try and get the 1st floor to show as an underlay in the basement plan, the roof plan shows up as the underlay instead. The basement works fine as an underlay on 1st floor. Any thoughts?
yes changes your view depth, drop the bottom to unlimited (unless you have a basement) in that case use the associated level, then mess with the cut plane.
http://familyjewels.typepad.com/ |
6 Posts No Rating |
OK, the cut depth helped. How about getting exterior walls that are attached to the roof to show in the underlay? Is that possible?
of course it is, keep messing about with the view range, it should come up, you may also want to hit the little light blub that reveals all the things that have been hidden.
Disregard my last post
Edited on: Mon, Aug 11, 2008 at 6:20:39 PM
- Core 2 Duo E8400 3ghz
- 756mb Nvidia 9600GSO 256bit
- 6gb Kingston RAM 800mz DDR2
- Windows XP Service Pack 3 32-bit
Underlay |
Thu, Oct 11, 2012 at 8:15:33 AM
Underlay is not working |
Mon, Apr 28, 2014 at 5:29:50 PM
REVIT 2015 - Underlay: EXPORT? |
Tue, Aug 5, 2014 at 2:54:54 PM
misguided underlay |
Tue, Feb 19, 2013 at 8:14:29 AM
wrong underlay showing |
Mon, Jan 27, 2014 at 1:29:57 PM
Members: | 2030612 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
