Forums >> Revit Building >> Technical Support >> Interior Rendering Problem
I am having problems with an interior rendering. It is a fairly large basement room with walkout. One side is all glass so it should let sun light in. When I render it it is all black - no light at all. Neither sunlight or interior lights show anything. I believe that my settings are correct. Interior: Sun and Arificial. All lights are on. In the custom settings the daylight portals like Doors and Windows are toggled. Do not have any problems with exterior renderings. Any idea ? Thanks
2008?
no 2009
16 Posts No Rating |
We are having the same problem in our office. Have tried many different combinations of lighting set ups but still a black render for all interior views.bucksy, was your project loaded in from a previous version ( 2008 )? that is the only thing we can put ours down to but cant see why it would effect it..
Edited on: Tue, May 13, 2008 at 8:48:57 PM
turn on your daylight portals! mental ray needs to know that the light is to travel through the glass.
24 Posts No Rating |
Hello folks, can u tell me where to download the Mental Ray user guide for RAC 2009.
Daylight portals for sure. May have something to do with the trace depth of the glass aswell. In my past life while working in Maya we could assign custom attributes to items like glass - like photo/FG pass through. The daylight portal check boxes should do the same. Looks like Autodesk are really trying to simplify MR settings within Revit. It would be nice to be able to customise these settings as much as you can in Max and Maya aswell as enable command line rendering.. Ahh the good old days - ray -v on -message geomi none -- -finalgather_rebuild freeze etc etc......
ummmm. why am i here?
Edited on: Fri, Jun 20, 2008 at 1:00:19 AM
Hi there, there is a bug with the Interior: Sun and Arificial setting in Revit 2009. You need to get the service pack that is listed on this forum as it has the fix for this is issue.
1 Posts No Rating |
I'm having the same problem with 2009 on a model updated from 2008. I've got the latest build per this thread but interior renderings are all black. I can render an exterior just fine. I've tried daylight portals on and off. I've got studio lights as well as recessed cans in my model. thanks!
Download the Service Pack to 2009 here: http://www.revitarchitecture2009.com/
Nice little 490 mb download.
"Studio Light" fixture work for me to get some good lighting inside.
I HAVE BEEN USING REVIT 09' AND HAVENT HAD ANY INTERIOR LIGHTING ISSUES. NOT SURE BUT I WOULD HAVE TO SAY YOUR MISSING A SETTING OR I GUESS U NEED THAT SERVICE PACK.
renderforfun, this thread has more than 1 year..........
