51 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Need help with Summing yes/no parameters
Fri, May 9, 2008 at 3:15:46 PM | Need help with Summing yes/no parameters
AVSteve
I need some help understanding conditional statements.  My desire is to have a parameter that will return the integer number of certain other parameters that are checked as 'yes'.  In other words, this summing parameters will return '3' when I have three of the five yes/no parameters checked as 'yes', then of course, when only one is checked as ‘yes’ it will return ‘1’. Any ideas?
Thank you for any help with this.
AVSteve
Fri, May 9, 2008 at 3:44:08 PM | Need help with Summing yes/no parameters
AVSteve
I just solved my own problem, with the help of google of course.
My example:
Up Throw = Yes
Down throw = Yes
Left Throw = Yes
Right Throw = Yes
 THEN
Throw = 4 = (if(Up Throw, 1, 0)) + (if(Down Throw, 1, 0)) + (if(Right Throw, 1, 0)) + (if(Left Throw, 1, 0))
AND
Up Throw = No
Down throw = Yes
Left Throw = Yes
Right Throw = Yes
THEN
Throw = 3 = (if(Up Throw, 1, 0))+ (if(Down Throw, 1, 0)) + (if(Right Throw, 1, 0)) + (if(Left Throw, 1, 0))
AND SO ON….
I hope this will help someone!
Edited on: Fri, May 9, 2008 at 3:44:49 PM
Edited on: Fri, May 9, 2008 at 3:46:14 PM
Fri, May 9, 2008 at 4:42:56 PM | Need help with Summing yes/no parameters
mhans
3 Stars: 10 Votes
Hi,
Thanks for sharing your problem and solution. You should do that more often.
Mhans
Motto: "No Post left behind"
Mystery parameters - shared?
Tue, Nov 10, 2015 at 7:06:20 AM
Titleblock Parameters [ 1 2 ]
Thu, Mar 13, 2014 at 4:57:53 PM
17
Instance Parameters in titleblock not linking
Wed, Dec 28, 2011 at 10:31:23 AM
12
Shared or Project Parameters?
Tue, Jan 19, 2010 at 7:01:11 PM
Shared Parameters - Schedules multiple parameters one column?
Thu, Oct 4, 2012 at 7:10:20 AM
Page generation time: 0.3401
