116 Users Online (115 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> RAC 2009 - Topo Site Work
Fri, May 9, 2008 at 1:49:54 PM | RAC 2009 - Topo Site Work
michael91077
4.5 Stars: 2 Votes
I am starting a new project based of a project done a few years ago. part of the set was the site plan with topo lines.I have got the topography just fine, but now when i try to link a cad drawing so i can get the correct property lines, there is no option for it come in on the Site level. is there a way that I can get this work so that the bioundaries of the site are on the site level itself, and not on the floor plan or anything else.
Fri, May 9, 2008 at 2:49:10 PM | RAC 2009 - Topo Site Work
4 Stars: 202 Votes
Hi Michael, sincerely i don't "figure" what's the problem, when you import the "TOPO" for CAD first of all i "ENTER" in my "SITE" level then i import the file, only in SITE level it's visible, if you can see your SITE in another level you must go the "VP" View Properties and change your "VIEW RANGE"
Fri, May 9, 2008 at 3:08:35 PM | RAC 2009 - Topo Site Work
michael91077
4.5 Stars: 2 Votes
i actually got it figured out shortly after i posted this. when importing the file, i needed to check the "Current view only" box so that it way it comes in on the site level. when i get it inserted, i hae to make the topo transparent so i can see the imported file.
importing topo info into RAC 2010 to create a toposurface
Thu, Apr 29, 2010 at 1:12:41 PM
Wall on Topo Site
Wed, May 28, 2008 at 5:00:39 AM
Problem with site shading with edges
Sun, Mar 8, 2009 at 3:59:33 PM
Project level vs. site topography RAC 2008
Tue, Jan 29, 2008 at 2:54:57 PM
Resizing topo?
Sat, Dec 5, 2009 at 7:16:50 AM
Page generation time: 0.9306
