Forums >> Revit Building >> Technical Support >> "Can't create stringers geometry"
4 Posts No Rating |
Okay, this is really odd. I'm working on a large atrium type area. I'm supposed to have two descending gently curving staircases from a balcony a ways up. They both have custom banisters and are open sided. The problem is that I have sucessfully completed one, the one on the left. However, every time I try in any way to make the one on the right I get a "can't create stringers gemetry error". I can't mirror the other one, hell, I can't even copy it. The copys get the same error. If I make a new one its fine until I try to set it to "2-sides open", or any side open for that matter. Somehow I got the first one to work and now I just can't recreate it. Any ideas?
4 Posts No Rating |
EDIT: I can't find an edit button. Apparently I can copy it, I just can't mirror it. Go figure.
It sounds like you may have a line in your stringer sketch that is too short for the stringer profile that you are using. Is this just a stair or a stair and some landings? Assuming your first stair is OK. Click on the stair and choose edit. Copy to clipboard. Quit the sketch. Start a new stair command and paste from your clipboard. Now mirror your skech with copy off and you should have it.
4 Posts No Rating |
Okay, tried that, gave me the same error. I've been fiddling around, and it looks like Revit just won't allow me to make a curved staircase of "Residential Open 2 Sides" type at all.
Here is a good example of the stairs you can create.
Edited on: Mon, May 12, 2008 at 12:35:37 PM
steel stair stringers under treads |
Mon, Jun 27, 2005 at 8:18:26 AM
"Constraints are not satisfied" |
Wed, Jun 7, 2006 at 8:17:24 AM
How to create spotlight "fall off" / "hotspot" ? |
Wed, Aug 23, 2006 at 9:51:57 PM
wall wrapping at curtain wall "inserts" |
Tue, May 20, 2008 at 6:29:51 AM
im trying to export dwg. gives can't create or file " jpg " already open!!!! |
Sun, Jul 28, 2013 at 9:55:30 PM
Members: | 2104598 | Objects: | 23178 | Forum Posts: | 152305 | Job Listings: | 3 |
