52 Users Online (51 Members):
Forums >> Revit Building >> Technical Support >> MATERIALS IN 3D VIEW
25 Posts No Rating |
is there a way i can view the materials in the normal 3d mode rather than having to render it to see it every time? i know u can do it in autocad so im hoping theres a way to do it here too
I don't think there is a way
regards
Pavan
If you set your 3D view to "shaded" or "shaded with edges" you will see an approximation of the colors that will show up in the rendering.
1 Posts No Rating |
You can use Settings/Materials to control how objects look in regular views, 3D views, and rendered views. By controlling each of the values you can have patterns and colors more or less coordinated among the different view types. There is a limit, of course, when you have a material for which there is a good surface pattern but you can't find a rendering pattern for that material. Spanish roof tile comes to mind here.
When i'm doing renderings i'll usually do a small region raytrace on the particular material i'm working on to trial and error the look...
That way i only have to wait about 10 seconds to get an indication of what the material is going to render like.
Materials in a camera view |
Mon, Mar 25, 2013 at 8:17:41 AM
Revit Materials - Rendering not working |
Tue, May 17, 2016 at 10:08:44 AM
Revit materials missing at rendering [ 1 2 ] |
Tue, Jun 14, 2011 at 11:24:21 PM
22
When editing materials through properties, only two show up?? |
Tue, Mar 13, 2012 at 3:38:21 PM
Adding materials into Revit's materials files |
Thu, Jul 22, 2010 at 1:54:48 PM
Members: | 2017260 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
