102 Users Online (101 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Transparent pdf
Thu, May 8, 2008 at 1:54:52 PM | Transparent pdf
esapc
Revit Architecture 2008.  Anyone know of a way to plot rasterized (i.e. advanced model graphics is on) elevations to pdf without having the white background show up?  The white background corrosponds with the crop region and it doesn't seem to matter if the crop region is visible or not.  You don't notice the background in Acrobat because the whole background shows as white but it becomes apparent in Photoshop.  I'm plotting through pdf995 software.  The image is a screen shot of how it displays in Photoshop.  The background can be removed at this point but I'm trying to figure out a way to get transparent backgrounds without the extra step.
Wed, Aug 20, 2008 at 9:21:39 AM | Transparent pdf
cganiere
cganiere Avatar
Have you tried exporting the file as an image instead of plotting to pdf?
Christopher Ganiere, NCARB, LEED AP
www.developmentone.net
Skype: ArchitectCRG
Thu, Feb 6, 2014 at 3:52:35 PM | Transparent pdf
johnkinder
cganiere
Edited on: Thu, Feb 6, 2014 at 4:08:50 PM
Wed, Feb 21, 2018 at 5:27:48 PM | Transparent pdf
carly0mcginn
Make sure your shadows and sunpath are turned off, print the PDF as a vector not raster image, and when you place it in Photoshop select "Bounding Box". When your PDF drops in Photoshop you'll have the linework only, no white background.
Print to PDF with transparent background!
Tue, Jan 25, 2011 at 8:12:04 AM
Transparent Floor Plan when printing to PDF?
Fri, Apr 17, 2009 at 1:06:26 AM
Help: Print transparent objects from floor plan view to pdf in revit 2013
Tue, May 8, 2012 at 2:49:42 PM
Need help with visibility/printing settings
Wed, Nov 25, 2015 at 10:11:30 PM
Transparent object
Tue, Sep 14, 2010 at 1:18:35 PM
Page generation time: 1.1990
