32 Users Online (31 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> SPLITTING WALL PANELS REVIT STRUCTURE 2009
Thu, May 8, 2008 at 11:58:01 AM | SPLITTING WALL PANELS REVIT STRUCTURE 2009
VANREVIT
VANREVIT Avatar
5 Stars: 2 Votes
Hello,
I am a Revit Structure Newbie in the Vancovuer BC Area. I have been Given as a first project a Square Tilt-up Building.
As some of you are aware Tilt-up Construction consist of Concrete Panels casted flat on a slab and tilted up into place.
I am trying to represent Each Panel as a single Entity. I created a new type of wall, and I drew the outline of the building with it. then I tryed to Split the wall where Panel Joint are supposed to happen. a Panel Joint is only 3/4" wide. I used the split tool to try to achive a 3/4" gap, but the wall kept on joining itself back again and again. Can anyone tell me if there is a setting I need to change for this not to happen?  or if you know another wy to achive this? I tried doing a full height opening as well but the wall remain as one entity instead of several panels. Thank you kindly in advance.
Vanrevit
Welcome to the REvitlution!!!
Thu, May 8, 2008 at 12:16:05 PM | SPLITTING WALL PANELS REVIT STRUCTURE 2009
coreed
coreed Avatar
4 Stars: 16 Votes
to keep the wall from joining, select the wall - right click over the blue dot at the end of the wall and select Disallow join
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, May 8, 2008 at 12:44:04 PM | SPLITTING WALL PANELS REVIT STRUCTURE 2009
VANREVIT
VANREVIT Avatar
5 Stars: 2 Votes
Thank you kindly for the response
Splitting a wall with a Reveal
Fri, Feb 19, 2010 at 11:25:44 AM
Can't delete Glazing or System panels in Revit Structure
Wed, Apr 17, 2013 at 9:57:51 AM
Trussed structure, screen panels..
Tue, Jul 1, 2014 at 12:15:24 PM
Rendering in Revit Structure 2009?
Sat, Dec 24, 2016 at 5:11:53 AM
curved wall panels
Sun, Jul 18, 2010 at 9:26:46 AM
Page generation time: 2.0863
