79 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Hello I Am New To Revit and need a question answered.
Thu, May 8, 2008 at 11:04:09 AM | Hello I Am New To Revit and need a question answered.
VANREVIT
VANREVIT Avatar
5 Stars: 2 Votes
Hello,
I am a Revit Structure Newbie in the Vancovuer BC Area. I have been Given as a first project a Square Tilt-up Building.
As some of you are aware Tilt-up Construction consist of Concrete Panels casted flat on a slab and tilted up into place.
I am trying to represent Each Panel as a single Entity. I created a new type of wall, and I drew the outline of the building with it. then I tryed to Split the wall where Panel Joint are supposed to happen. a Panel Joint is only 3/4" wide. I used the split tool to try to achive a 3/4" gap, but the wall kept on joining itself back again and again. Can anyone tell me if there is a setting I need to change for this not to happen?  or if you know another wy to achive this? I tried doing a full height opening as well but the wall remain as one entity instead of several panels. Thank you kindly in advance.
Vanrevit
Welcome to the REvitlution!!!
Thu, May 8, 2008 at 12:13:32 PM | Hello I Am New To Revit and need a question answered.
coreed
coreed Avatar
4 Stars: 16 Votes
to keep the wall from joining, select the wall - right click over the blue dot at the end of the wall and select Disallow join
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, May 8, 2008 at 12:43:32 PM | Hello I Am New To Revit and need a question answered.
VANREVIT
VANREVIT Avatar
5 Stars: 2 Votes
Thank you kindly for the response.
Fri, May 9, 2008 at 7:21:59 AM | Hello I Am New To Revit and need a question answered.
IDN101
2.5 Stars: 3 Votes
Have you considered making these as a custom component, that you can then array into place?
 Regards,
Ian
www.RevitZone.com
News / Articles / Tutorials / Forums / Beginners Guide to Revit
Sat, May 10, 2008 at 11:56:04 AM | Hello I Am New To Revit and need a question answered.
VANREVIT
VANREVIT Avatar
5 Stars: 2 Votes
I have considered it, but Panels can be all kinds of differente sizes within oone wall. hen there is adding openings and editing the shape of the panel (ie. If the panel top is sloped or if it has a weird shape. Cheers!
 Vanrevit
Mon, May 12, 2008 at 3:27:58 AM | Hello I Am New To Revit and need a question answered.
IDN101
2.5 Stars: 3 Votes
You could add parameters to control all the variables you mention (overall size, opening or not, sloped top)
 This would then allow you to schedule all your panel types.
Just a thought!
Cheers,
Ian
www.RevitZone.com
REVIT ANSWERS DIRECTLY
Mon, Jul 30, 2007 at 11:22:20 PM
Rounding in Formulas
Wed, Mar 13, 2013 at 8:25:56 AM
tEXT jUSTIFICATION
Wed, Jun 20, 2018 at 11:10:10 AM
It is a really slow day on revitcity
Tue, May 26, 2009 at 8:38:24 AM
14
Sloping Bar Joists?
Thu, May 7, 2009 at 9:41:09 AM
Page generation time: 2.2392
