23 Users Online (22 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Constraining Structural Column Within a Revit Family
Thu, May 8, 2008 at 9:58:04 AM | Constraining Structural Column Within a Revit Family
Gils
While modeling a modular prefab component using structural components I ran into a problem.
It is possible constraing columns to a grid line intersections, but within a family environment, where there are no grids it seems it is impossible to constrain a column to two prependicular ref. planes, only one.
Reason for doing that is to give the modular component variable sizes through family types, therefore having a dimension between grid lines controlling module size is not an option.
 Any ideas?
 Regards,
Gils
Thu, May 8, 2008 at 10:47:22 AM | Constraining Structural Column Within a Revit Family
You could add two hidden lines to your family.  Dimension (label - instance dimension) those off your xy insertion point and then use that variable to calculate your xy family size.  When you insert the family, you can stretch the two invisible lines to your grid spacing and that will then flex your family size according to your calculations.
I just tried this and it works.
Fri, May 9, 2008 at 3:22:04 AM | Constraining Structural Column Within a Revit Family
Gils
Thanks a lot.
Apparently it was more to do with lack of my experience with structural components. I had used Structural framing family instead of columns Smile
 I just substituted those to structurl columns and eveything is working.
structural column family
Tue, Oct 25, 2005 at 9:29:56 AM
structural column member not selectable
Wed, Jul 19, 2006 at 9:26:06 AM
Visibility graphics of a structural column
Mon, Aug 16, 2010 at 8:21:00 AM
Creating and inserting family types
Mon, Sep 23, 2013 at 4:23:25 PM
Structural Column Family file
Thu, Jul 14, 2011 at 10:44:21 AM
Page generation time: 2.6202
