55 Users Online (54 Members):
Forums >> Revit Building >> Technical Support >> Finding and Replacing Text
2 Posts No Rating |
Is there a command in Revit similar to Autocad where you can find and replace text?
REVIT dosen't have a find replace utility (Haven't been brave enough to try 2009 yet), but there are some clever people out there who have done somthing about it. I can't remember where I found this. Works for REVIT 2008, read the .txt file to install. Once done you'll have 'Find replace' under 'Tools - External tools' HTH Luke Edited on: Mon, May 12, 2008 at 8:52:23 PM
Edited on: Mon, May 12, 2008 at 8:52:52 PM
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
If you install the VSTA add on, which is the built in Revit API script writer, I believe there is a sample script for this that you could use.
Regards,
Chris.
2 Posts No Rating |
Thank you guys. I appreciate it.
![Dianthier Avatar](user_avatar/38486.jpg)
![2.5 Stars: 3 Votes](/images/stars_2.5.gif) |
" REVIT dosen't have a find replace utility (Haven't been brave enough to try 2009 yet), but there are some clever people out there who have done somthing about it. I can't remember where I found this. Works for REVIT 2008, read the .txt file to install. Once done you'll have 'Find replace' under 'Tools - External tools' HTH Luke " Where is the txt file? There is only an .ini and .dll file in the zip when I open it. How do I install this? Thanks Diane
It's got to be happy hour somewhere |
Edited on: Mon, May 12, 2008 at 10:16:48 AM
Dang! Why did my question post doubles?
Sorry Here's the .txt file! Luke
Overriding tag text w/o breaking link? |
Thu, Jul 9, 2015 at 9:53:24 AM
Text formatting (bullets & indents) |
Wed, Jun 11, 2008 at 8:49:15 PM
Select all instances - finding the one |
Sat, Jun 18, 2011 at 8:13:20 AM
Superscript/subscript/degree text symbols in Revit |
Wed, Jul 5, 2017 at 9:10:49 AM
Finding Consultants who use Revit |
Thu, Mar 10, 2016 at 1:45:54 PM
Members: | 2022252 | Objects: | 22975 | Forum Posts: | 152202 | Job Listings: | 3 |
