49 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Aligning Dependent View across Sheets
Wed, May 7, 2008 at 11:36:07 AM | Aligning Dependent View across Sheets
rickie
I am working with dependent plan views of one large building plan and I want to align them so that they appear on the sheets in the same position. This will also apply to building sections and wall sections. I have several sheets of wall sections and I would like to align them across all the sheets but I cannot snap to anything in the view or dimension from the edge of the sheet to anything in the view.
Wed, May 7, 2008 at 11:41:51 AM | Aligning Dependent View across Sheets
What you can do is to add detail lines in "paper space" - copy to clipboard and paste same place on your other sheets.  Now when you place a view, you can aling it to this line visually.  I find that I can nudge it close - then when you zoom in, your nudge gets smaller and you can align it even closer.
Dependent views not the same as Parent view...
Fri, Jun 16, 2017 at 11:02:18 AM
Adding / Aligning Legends to multiple sheets
Fri, Oct 17, 2014 at 9:03:43 AM
Dependent View Question. [ 1 2 ]
Tue, Sep 14, 2010 at 9:07:33 AM
21
Project Browser - Dependent Views
Wed, Jun 17, 2015 at 10:57:21 AM
Aligning Sheets (Titles, Viewports, ETC.) HELP!
Tue, Mar 11, 2008 at 1:25:09 AM
Page generation time: 2.7847
