70 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Wall Cuts
Wed, May 7, 2008 at 8:37:31 AM | Wall Cuts
stevenson1971
When I create a wall using the modelling tab and selecting a wall family the wall cuts correctly in plan but shows everything below, including objects below the veiw plane, this does not occur if I create a wall using the built in wall command.
I am modelling an existing facade and need to generate varying wall thicknesse, copings etc.
 Has anyone else come across this and is there a work around for it
Wed, May 7, 2008 at 10:12:15 AM | Wall Cuts
That is the problem when you don't use walls, sweeps etc to do what you are doing.  True walls are handeled differently than model elements that you classify as walls.  You could break down your "wall" into floor to floor "walls" and that might work for what you are doing.  I personally would do it as true walls and add sweeps.
Wed, May 7, 2008 at 11:49:42 AM | Wall Cuts
stevenson1971
I will try that, It will be akward though as the existing facade has tapered and varying thickness walls that will prove difficult to model.
Oh well, perhaps this will be adressed in future.
Many thanks
 Spencer
Wed, May 7, 2008 at 12:04:07 PM | Wall Cuts
The varous thickness's can be handled as seperate walls / compound walls or walls with in place or added sweeps or voids.  I think a tapered wall could even be down with a tall reveal (a negative "wedge"Winking or a tall sweep (positive "wedge"Winking but I must admit that I have not had to do this ... yet.
Please let us know what works.
Thu, May 22, 2008 at 6:22:37 AM | Wall Cuts
stevenson1971
I thought i would update you with my retained facade,
Using walls/sweeps worked perfectly,
Thanks for your advice
Spencer
Wall Sweep Overlaps window frames and cuts (some not all)
Mon, Jun 22, 2015 at 8:09:40 AM
Concrete Columns and Beams cuts through wall...
Mon, Feb 4, 2013 at 8:10:15 AM
wall cuts
Thu, Jul 26, 2007 at 12:18:17 PM
Wall Sweep only cuts out window not trim
Mon, Aug 18, 2014 at 10:34:16 PM
Wall hosted familes cutting through 2 types of walls
Thu, Oct 27, 2011 at 10:42:15 AM
Page generation time: 1.2254
