54 Users Online (54 Members):
Forums >> Revit Building >> Technical Support >> Exporting sheets to dwg with shared coordinates
5 Posts No Rating |
Hi, Is it possible to export sheets to dwg and have the 2D modelspace drawing be located with the same coordinates as the Revit file? We have been trying to export all of our project sheets to dwg, so that our consultants can xref our drawings into theirs and have them fall into place. We have specified the N/E coordinates in our Revit file, although when we open an exported (sheet) dwg plan and go to modelspace, the UCS/coordinates are incorrect and seem to just be a result of a random placement of the viewport. We have tried selecting both Internal and Shared coordinates in the options, as well as printing to single and seperate files. Nothing seems to work?! TIA
This is a known and annoying limitation. When exporting from a sheet the shared co-ordinates are not exported. In order to get the correct co-ordinates you need to export from the view and not the sheet. HTH.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
Exporting with shared coordinates |
Tue, Jun 10, 2008 at 8:54:53 PM
Shared Coordinates while linking Dwg into Rvt |
Thu, Jun 5, 2014 at 12:06:32 PM
Maintaining 0,0 when exporting a DWG (REVIT 2009) |
Fri, Sep 25, 2009 at 11:58:43 AM
Exporting to DWG and maintaining 0,0 |
Tue, Nov 10, 2009 at 6:34:17 PM
Exporting to DWG using shared co-ordinates only works from Views, not Sheets |
Thu, Oct 23, 2008 at 1:25:50 AM
Members: | 2017222 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
