148 Users Online (147 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> How to build a 'V" shaped roof for school project, !Please help fast!
Tue, May 6, 2008 at 8:09:34 PM | How to build a 'V" shaped roof for school project, !Please help fast!
Pointman73
Im building a green home for school, and I'm building a design that has a reverse pitched or "V" shaped roof (to catch the water) that will be metal sheeting, and it will fit right into the supporting walls, so it can't be a big object like revit builds roofs.
 Any help is greatly appreciated!
 It needs to be something like the attached picture
Tue, May 6, 2008 at 11:16:34 PM | How to build a 'V" shaped roof for school project, !Please help fast!
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
What do you mean by "it can't be a big object like revit builds roofs"?  Revit builds roofs to the thickness and make up that you specify.  The roof you show is very easy to create using Roof by footprint and assigning negative pitches or using roof by extrusion and just drawing the V shape in a section or elevation and extruding out the shape.
HTH.
Regards,
Chris.
Wed, May 7, 2008 at 9:17:57 PM | How to build a 'V" shaped roof for school project, !Please help fast!
Pointman73
First off, thankyou for taking the time to reply, my choice of words was bad, but I was playing with it and was able to get what i wanted very easy by doing roof by extrusion.  My only problem now is how to get the walls to meet that roof in that "v" shape...........
Thu, May 8, 2008 at 5:34:08 AM | How to build a 'V" shaped roof for school project, !Please help fast!
tawhiri
Join geometry? both roof and wall....
Thu, May 8, 2008 at 12:08:17 PM | How to build a 'V" shaped roof for school project, !Please help fast!
Pointman73
No, that doesn't work....thanks
Thu, May 8, 2008 at 12:53:27 PM | How to build a 'V" shaped roof for school project, !Please help fast!
4 Stars: 202 Votes
Really i don't no what's the problem but if you want walls goes to the roof pick in the wall and then pick in "ATTACH", (by default was "TOP"Winking and pick in the roof, that's all...
Solution for my school project.
Tue, Dec 13, 2005 at 11:52:08 PM
Need some assistance
Sun, Dec 25, 2005 at 1:31:11 PM
Does anybody know how to build the roof connection of Nasher Sculpture Museum?
Mon, Oct 7, 2013 at 8:44:42 AM
How to build a cocoon shaped building?
Wed, Apr 13, 2011 at 5:37:18 AM
How to build a roof with different slopes?
Sun, Aug 29, 2010 at 7:34:22 PM
Page generation time: 4.5950
