23 Users Online (22 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> Tilt Panel Concrete Walls
Tue, May 6, 2008 at 5:11:14 PM | Tilt Panel Concrete Walls
michael91077
4.5 Stars: 2 Votes
Has anyone made a wall type for a tilt panel wall? we noticed that RAC 2009 does not come with that out of the box. I know there is one in the Structural library, under framing, but you can not insert doors/windows into it because it is not a wall.
Tue, May 6, 2008 at 11:31:34 PM | Tilt Panel Concrete Walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
This is very easy to do.
First setup a Basic Wall for the concrete part to the thickness you desire.  Lets say 150mm
Now duplicate the curtain wall system and create one called Tiltup panel or whatever you want.
Now setup the system, set the panels to be the 150mm concrete basic wall you just made, you should also create a profile for your joints and then setup a mullion type to use this profile.  Then setup your curtain wall to use this mullion for Grid 1 & Grid 2.
Thats it.  Just draw your wall and add grids as necessary and the mullions will be added automatically.  As your panels are basic wall you can still host doors and windows to them...
HTH.
Regards,
Chris.
Wed, May 7, 2008 at 9:20:03 AM | Tilt Panel Concrete Walls
michael91077
4.5 Stars: 2 Votes
that seems like a long drawn out process for such a simple thing.i can make the wall itself, and get it to look the way i want, with the joints. i guess really what we need to be able to do is update the template with the wall style that was made, that way it loads with the template when you start a new project. Revit is a great program, but there are things that could have been done better.
Tue, May 13, 2008 at 7:12:43 PM | Tilt Panel Concrete Walls
lunchtrayrider
3.5 Stars: 7 Votes
I think that what mr spot is talking about is really easy.  you simply draw a curtain wall (and tilt-up is more or less a curtain wall right?) and draw in the grids and then switch out the glass panels for concrete walls.  The curtain wall can be a very powerful tool too.
Wed, May 14, 2008 at 2:09:04 AM | Tilt Panel Concrete Walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
"Long drawn out process"???
It takes 30 seconds to do, do once in your template and then its always there for you to use...  Give it a try.
Regards,
Chris.
Thu, Jun 12, 2008 at 11:17:14 AM | Tilt Panel Concrete Walls
JGATOR
I just got through a tilt-wall project. I used a "Basic-Wall" any thickness will do. I went into the properties, "Edit"-"Duplicate"-renamed it Tilt-Wall 7.25" and then changed the structure to cast-in-place concrete that was 7.25" thick. You can then add a curtain wall-storefront and windows and doors just like any other wall.
Tue, Nov 4, 2008 at 7:08:14 PM | Tilt Panel Concrete Walls
rick_tiger
Hello
I am preparing a concrete tilt panel building, I ahve created the Curtain wall system as mentioned and it works for walls at 90deg. I have a couple of walls whuich are not at right angles, thus it seems hard to place mullion at an angle between the angle of the two walls.
 I am tempted to use normal tilt panel walls and then create the panels as soilds, but this would not update the solids if i change the walls or opennings.
 Does anyone have any ideas how we can manipulate Revit to work the way I want it to.
Would i have to creat a mullion with adjustable angles?
Wed, Dec 10, 2008 at 9:09:12 PM | Tilt Panel Concrete Walls
akccrox
Thsnkd for the helpful information Mr. I will certainly try this on my next proct. I had used a basic wall (concrete) in the past and placed face based voids for my profiles but this would seem to be a much more user friendly way of doing it.
Thanks again
Tue, Jan 20, 2009 at 5:33:16 PM | Tilt Panel Concrete Walls
pwiklund
Nice idea Mr. Spot, that could even work for a pre-engineered metal panel building.
Peter
Thu, Nov 30, 2017 at 9:53:05 PM | Tilt Panel Concrete Walls
brankulo
what is the advantage of curtain grid method vs parts method for creating panels? using parts i can have entire shell have set up with panel joints based on grids in seconds. also miter panel joints are no problem. just wandering as i am starting tilt up project and want to use proper method.
Concrete panel 'tilt ups'
Thu, Oct 30, 2014 at 8:11:10 AM
Newb Question: Tilt Up Panel
Fri, Apr 16, 2010 at 1:00:49 PM
12
Tilt-up concrete PM in Revit
Mon, Oct 24, 2016 at 10:16:51 AM
Problems with offset joints in tilt-up concrete walls
Fri, Jul 1, 2011 at 11:01:16 AM
Tilt-Up Warehouse
Fri, Nov 1, 2013 at 10:48:00 AM
Page generation time: 7.6126
