70 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Section or elevations not cutting imported dwg's
Tue, May 6, 2008 at 1:43:51 PM | Section or elevations not cutting imported dwg's
jbaysinger
3 Stars: 4 Votes
Hello there, I am using revit arch. 2008.  What I have done is imported coordinated mep cad files into my architectural model in revit.   When I go to cut a section or an elevation, I see the whole mep cad files, and not just the view depth of the sections or elevations.  What I am trying to do is to take an elevation of a wall and be able to dimension the wall with the mep's.  ??  Is there a way that I can do this so that I can actually cut those cad files where the view depth of the elevations or sections actually work?  I kind of just want the elevation of the walls with the protrusions??  Thanks
JB
Tue, May 6, 2008 at 1:51:10 PM | Section or elevations not cutting imported dwg's
Sorry, I don't think you will be able to do what you want.  Assuming they are 3D, AutoCAD imports are not cutable.
Tue, May 6, 2008 at 3:34:53 PM | Section or elevations not cutting imported dwg's
jbaysinger
3 Stars: 4 Votes
Thanks!
Fri, May 9, 2008 at 3:30:44 PM | Section or elevations not cutting imported dwg's
UserError
UserError Avatar
3 Stars: 1 Votes
CAD objects can indeed be cutable.
What I do is to import the *.dwg into an empty Revit project into an empty, in-place family component. Revit really sux at this btw and even small files can lock up your session. The largest file that I have used about 16 megs. Start a brand new Revit session if you have problems. The final step is to then import your component/project file into your working project file.
There might be a difference if the 3d model is made of up from solids or a polymeshes. I have gotten this to work with ACIS solids.
Section cut through the imported dwg file
Wed, Jun 26, 2013 at 4:00:40 PM
12
Section through a family object and imported dwg file
Fri, Mar 26, 2010 at 12:41:24 PM
Revit Not Cutting Through Imported .dwg 3D Model
Mon, Jan 19, 2015 at 2:05:11 PM
Cutting an imported solid in plan and section?
Tue, Jul 29, 2008 at 9:45:49 AM
Topo Surface using ACAD dwg
Fri, Jul 7, 2006 at 2:13:08 PM
Page generation time: 0.8522
