61 Users Online (59 Members):
Forums >> General Discussion >> Revit Project Management >> Elevation Marker
![notagain Avatar](user_avatar/36981.jpg)
![4 Stars: 1 Votes](/images/stars_4.gif) |
Is there way to create two seperate groups of elevation markines on one view. For example there would be a group A and group B....both in the same location, looking in the same direction But you would Have the ability to turn one set off on one view, and one off on the other?
I really want this to work...some good things some bad |
![3.5 Stars: 393 Votes](/images/stars_3.5.gif) |
Just create two sets and place them on top of each other then toggle through them and hide in view the ones you don't want.
![3 Stars: 10 Votes](/images/stars_3.gif) |
Hi, If you are trying to group the elevation tags, I'm sure you already found out that you cannot. Depending on your need you can try to duplicate the view with detailing as many as you like and hide/show the things you want. This avoids hiding or showing things by picking them over again...w/c could have been easy if you can group tags. Thanks, Mhans
Motto: "No Post left behind" |
Split a an elevation marker up for mulitple sheets |
Tue, Oct 4, 2016 at 2:29:34 PM
Adding a reference elevation to an existing elevation marker? |
Wed, Sep 17, 2014 at 7:57:46 AM
ELEVATION MARKER |
Thu, Sep 10, 2009 at 2:55:39 PM
If your elevation markers on plan disappear. |
Fri, Mar 4, 2016 at 3:40:45 PM
One View Elevation Marker |
Wed, Jul 9, 2008 at 6:27:41 AM
Members: | 2026645 | Objects: | 22994 | Forum Posts: | 152211 | Job Listings: | 3 |
