50 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> leader without text
Mon, May 5, 2008 at 2:25:14 AM | leader without text
Fluffyfatcat
3.5 Stars: 3 Votes
 i need to draw leader without text
 is that possible?
Mon, May 5, 2008 at 11:43:54 AM | leader without text
Why don't you build an annotation family for this and post it here?
Mon, May 5, 2008 at 3:13:26 PM | leader without text
JHectorne
Check the downloads section "Uncategorized" for blank leader; I believe I found one on here.  It has no text associated with it, and you have the option for multiple leaders.  HTH
Mon, May 5, 2008 at 4:49:58 PM | leader without text
dano3d
3.5 Stars: 3 Votes
I've had the same need... leader without text.
My solution has been to simply use a "period" as the text.
This allows me to use the same arrow styles that are used WITH the text.
If the period looks to messy, perhaps you could use an "invisible font" or a blank "wingding".
My leader is attached in the project below.
Dan-o
Wed, May 14, 2008 at 12:12:05 PM | leader without text
jmsfuentes
You can also just make a new text type that you name NO Text. On that, make the text really tiny where it wont print out.
Multiple Leader Text
Sun, Nov 18, 2007 at 12:33:41 PM
ARC LEADER NO TEXT
Thu, May 2, 2013 at 10:36:05 AM
Distance from leader to text... Revit 2010
Tue, Jun 1, 2010 at 9:13:52 AM
distance between text and leader lines able to be changed?
Fri, Sep 12, 2008 at 10:20:22 AM
EDITING TEXT LEADER ARROWHEADS AND LINES
Thu, Aug 14, 2008 at 3:21:21 PM
Page generation time: 1.9118
