44 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit 2009 Wall Base Extension
Fri, May 2, 2008 at 12:23:39 PM | Revit 2009 Wall Base Extension
eyeeye
Wall base extensions were easy in Revit 2008 -- just edit the wall properties in section view and unlock each piece of the sandwich.
They've changed the process in 2009 -- there's no padlock to click when I select a sandwich piece.  How does it work now?
Thanks so much for your help!
- eye
Mon, May 5, 2008 at 8:27:31 AM | Revit 2009 Wall Base Extension
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I didn't see any difference in this function. Make sure you are clicking the Modify button in the section properties.
Mon, May 5, 2008 at 11:03:53 PM | Revit 2009 Wall Base Extension
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Agreed there is no difference with this functionality in 2009.
Regards,
Chris.
Base Extension Distance + Wall Sweep (at base)
Wed, Jun 3, 2015 at 6:26:49 PM
Wall Base Offset... one works, one doesn't. Why?
Wed, Jun 10, 2015 at 2:53:52 PM
Wall Joins Disappear When Base Extension Distance Parameter Not Zero
Wed, Oct 12, 2016 at 3:26:45 PM
Wall Footing on Walls w/ Modified Base Extension
Thu, Nov 21, 2013 at 12:06:48 PM
Railing without extension
Fri, Oct 2, 2009 at 10:54:50 AM
Page generation time: 3.6571
