70 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> deck profile is not loaded
Fri, May 2, 2008 at 7:06:08 AM | deck profile is not loaded
emosms
hallo
i use rack 2008.i want to set a layer in a floor slab with a function as structural deck.I saw some old posts that this function hasnt been functional yet.the posts were from 2008.so can i use it in rac 2008?i load any kind of profiles and the result is:"deck profile is not loaded.to create a structural deck load deck profile first".where is the deck profile?????
Fri, May 2, 2008 at 7:06:59 AM | deck profile is not loaded
emosms
the posts were from 2006 not 2008.i did a mistake
Fri, May 2, 2008 at 10:35:28 AM | deck profile is not loaded
TABEST
4 Stars: 4 Votes
we got our deck profile from our structural guys... It was/is functional, as we saw the profiles prior to upgrading to 2009.  Try these:
Fri, May 2, 2008 at 3:55:23 PM | deck profile is not loaded
emosms
First i want to tank you.
This deck profile families are ok, but i still dont get it.
I made a section of my floor and with detail level set to fine i cant see the repetative patern of the structural members within the deck.of maybe i misunderstoof the purpose of the structural deck?
Mon, May 5, 2008 at 9:47:46 AM | deck profile is not loaded
TABEST
4 Stars: 4 Votes
I honestly can't explain, because we also had the same issue you are describing... then magically, and I mean magically, one day the pan deck was there and showing...  The only thing I can think of is that we copied our floors from our structural consultants model... I just tried making a floor with decking in 2009, and it also didn't work.. i'll try to get you an empty project file with the floor types in it, and see if that works when you transfer project settings...
Mon, May 5, 2008 at 1:29:01 PM | deck profile is not loaded
emosms
even manualy detailing, it is MUCH MUCH BETTER than ADT
Metal Deck profile question
Thu, Jun 1, 2017 at 11:16:20 PM
steel deck profile
Mon, Apr 24, 2006 at 4:59:54 PM
Metal Structural Deck on Floor
Tue, Jul 12, 2005 at 10:06:29 AM
Metal deck roof profile
Fri, May 13, 2011 at 1:05:51 PM
Deck Railing: Grrrrr!
Tue, Feb 20, 2007 at 8:28:29 AM
Page generation time: 0.5502
