90 Users Online (89 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Blank filled Region
Thu, May 1, 2008 at 6:43:49 PM | Blank filled Region
KatWill
Hi all, relatively new to revit, and i'm trying to create linetypes with text in them, have found the workaround, but it talks about using a no pattern filled region. Can't seem to create a filled region with no pattern, if use the soild pattern i can't get it to send to back and my inported text from autocad is hidden by the pattern
Thu, May 1, 2008 at 11:27:46 PM | Blank filled Region
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
What method are you using?
The way it should be done is with a line based detail component and you nest a detail component of the letter written with lines into this family and array it.
Blank Filled Regions were phased out in 2008.  They are now Masking Regions.  Trying using these.  If you still have issues, be really nice to me and I'll post an example file for you Smile
HTH.
Regards,
Chris.
Fri, May 2, 2008 at 12:02:35 AM | Blank filled Region
KatWill
Thank you, that appears to work, but you cant have a topsurface in the back ground otherwise the masking region removes the surface colouring aswell, or is there a way around this.
Cheers & beers
Kathie
Fri, May 2, 2008 at 12:18:11 AM | Blank filled Region
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Don't use a Masking Region then, it is there to conceal the line. You cannot conceal the line and not the background.
Regards,
Chris.
Fri, May 2, 2008 at 12:30:12 AM | Blank filled Region
KatWill
Cool, thank you very much for your help
Cheers & Beers
Kath
Need Family w/ scaled Filled Region and Label
Fri, Oct 25, 2013 at 6:44:04 AM
Remove Model Filled Region @ Fixtures
Wed, Aug 15, 2012 at 4:19:33 PM
Deleting Types From Filled Region Families
Tue, Sep 9, 2008 at 6:56:41 PM
filled region pattern color changes when drawing scale changes
Thu, Apr 14, 2016 at 7:32:06 AM
filled regions and display orders
Wed, Apr 26, 2006 at 4:46:29 PM
Page generation time: 0.4357
