66 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Downloading a new hatch and applying to Revit... how?
Tue, Mar 29, 2005 at 11:43:53 AM | Downloading a new hatch and applying to Revit... how?
justinmthomas2003
I am trying to apply flagstone hatch I downloaded from this website for my floor on my project in Revit and it ended up all black, not hatch pattern. Can anyone explain to me how to do it properly? Also if I want to create my own hatch.. how do I do that? I've tried to do it on Revit and save it as pat file.. it won't work.. Can anyone explain to me how? Post edited on 2005-03-29 12:17:22
Tue, Mar 29, 2005 at 3:28:47 PM | RE: Downloading a new hatch and applying to Revit... how?
TomDorner
4.5 Stars: 25 Votes
Make sure that when you import the pattern that you highlite the pattern name again in the box to the right of the import button. It is not good enough to just see the name of the pattern in the "name" box above. It took me a couple of months before I finally figured this out. Also, make sure you set the scale correctly. It make take a bit of trial and error. To create a hatch you can use a text editor or you can find hatch creators on some of the CAD shareware sites. Revit uses the same hatch patterns as AutoCAD with the exception of an additional header line. Most of the time you can find enough patterns to download and use for free though. Hope this helps, Tom
Thu, Apr 28, 2005 at 11:17:52 AM | RE: Downloading a new hatch and applying to Revit... how?
johnfire
I am trying to do this and I cannot adjust the scale of the hatch. Both of the scale boxes are greyed out so they cannot be edited. Am I not doing something correctly?
Thu, Apr 28, 2005 at 12:10:15 PM | RE: Downloading a new hatch and applying to Revit... how?
TomDorner
4.5 Stars: 25 Votes
Make sure that after you have browsed for your .pat file that you once again highlight the name of that file in the box to the right of the "import" button. Once the file name is hightlighted then the scale boxes should un-grey and the name of the pattern appear. Everything should then work. Tom
Thu, Apr 28, 2005 at 12:20:34 PM | RE: Downloading a new hatch and applying to Revit... how?
johnfire
Thanks that did it. So simple but yet so difficult.
Thu, Apr 28, 2005 at 12:32:38 PM | RE: Downloading a new hatch and applying to Revit... how?
TomDorner
4.5 Stars: 25 Votes
This issue seems to stump just about everyone who tries to import a pattern. I know it stumped me for days before I stumbled upon the answer as it is not obvious. I think a clean-up of the code for that dialog box in Revit is in order and long overdue. Tom
Thu, May 19, 2005 at 12:46:18 PM | RE: Downloading a new hatch and applying to Revit... how?
cubman
How do you import the hatch pattern and where should I store these hatches?
Thu, May 19, 2005 at 6:52:04 PM | RE: Downloading a new hatch and applying to Revit... how?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I've created a folder in our office library named (you guessed it) hatch patterns and store them all here. To load a hatch pattern. Go to Settings-->Fill Patterns select whether you are loading a drafting or model pattern. (drafting is 2D and thus will appear different at different scales, model is 3D and thus spacing is a fixed 3D distances and will be the same in all views regardless of scale) Select New Choose custom then browse for the file. Select the pattern in the window. Set the import scale Name the pattern Click okay. HTH.
Fri, May 20, 2005 at 9:09:25 AM | RE: Downloading a new hatch and applying to Revit... how?
cubman
Thanks for the info Mr. Spot
Sat, May 21, 2005 at 12:51:56 AM | RE: Downloading a new hatch and applying to Revit... how?
arnosandoval
5 Stars: 3 Votes
Question about hatching, When you crate a hatch pattern in Revit, I can view it fine all 2D views, but when I drop a camera and look at a perpective shot(Hidden LIne), the pattern becomes black. Any fixes to that problem?
Sat, May 21, 2005 at 12:52:01 AM | RE: Downloading a new hatch and applying to Revit... how?
#11
arnosandoval
5 Stars: 3 Votes
Sun, May 22, 2005 at 8:49:18 PM | RE: Downloading a new hatch and applying to Revit... how?
#12
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Make sure you are using a model pattern as opposed to a drafting pattern.
Mon, May 23, 2005 at 8:34:28 AM | RE: Downloading a new hatch and applying to Revit... how?
#13
arnosandoval
5 Stars: 3 Votes
That was the problem, I was using drafting Pattern and not Model Pattern, problem fixed, Thanks.
applying multiple hatch to wall
Wed, Jan 2, 2013 at 5:35:11 AM
Imported hatch patterns appear corrupted
Thu, May 21, 2015 at 3:16:54 PM
Downloading Components from Revit City Problems
Mon, Sep 11, 2006 at 9:51:51 AM
downloading patterns
Thu, Jun 8, 2006 at 11:56:48 PM
Applying paint to infill wall
Fri, Sep 23, 2022 at 5:02:15 AM
Page generation time: 1.6929
