79 Users Online (78 Members):
Forums >> Revit Building >> Technical Support >> Sloped top of stone wall with wall cap on top
10 Posts No Rating |
I have an exterior stone wall with the top of it just below a concrete stair stringer. I want to place a cap on the wall so that there's a slight projection out from the wall face (similar to a water table) as it follows the slope down to the ground. Is it possible to do this with a sweep? If so how? If not what's the best solution?
There a few options...
One, is use my tutorial (not in the tutorial list yet?) search it was uploaded in a post. This explains how to trim a wall to the underside of a stair.
If you want a smooth top as opposed to step, use a ramp to the thickness of the wall. Two different ramps most likely, one for the stone cap and one for the other material.
Then have a normal wall come up to the underside of the ramp.
HTH.
brick cap at top of wall [ 1 2 ] |
Sat, May 7, 2016 at 3:13:55 PM
16
Precast Cap on wall profile sketch |
Thu, Mar 23, 2006 at 2:31:12 PM
Curved Wall Cap |
Tue, Sep 6, 2005 at 2:38:44 PM
How to make the top of the wall not horizontal? |
Sun, Jan 23, 2011 at 7:17:41 AM
Wall Sweep for 2 x 6 Sill and 4" Cap Block |
Thu, Feb 11, 2016 at 9:15:08 AM
Members: | 2022458 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
