155 Users Online (153 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> File locations in Revit 2009
Thu, May 1, 2008 at 11:22:28 AM | File locations in Revit 2009
eyeeye
We just upgraded to Revit 2009 and we can't customize our shortcuts in the "open" or "save as" menu anymore!  In 2008, we could at least add some (without going to Favorites first, which is what we have to do now).  How can we add direct shortcuts in 2009?
And on the same note, how can we remove the annoying "My Network Places" and "My Computer" shortcuts?
A million thanks... I know a lot of us are having this issue...
Smile,
eye
Thu, May 1, 2008 at 11:30:30 AM | File locations in Revit 2009
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I don't think you can remove default items, but you should be able to just click and drag a folder into the shortcut are and it will keep it as a shortcut.
Thu, May 1, 2008 at 11:37:47 AM | File locations in Revit 2009
eyeeye
Thanks... now can I rename the shortcut?
Has anyone else been able to remove default shortcuts?
Smile,
eye
Thu, May 29, 2008 at 6:02:30 PM | File locations in Revit 2009
ThatGuy
if its what I'm thinking, maybe wrong
you can customize your shortcuts under the settings menu / optons then click the tab " File Location" in there is a button that says places, click that and it takes you to a screen so you can add or delete shortcuts.
Hope this helps
Have a Great Day Smile
Any problems with modifying installation file locations?
Tue, Mar 10, 2009 at 10:04:19 PM
I need to open a Revit 2011 file into the Revit 2009 ? Are there any way ? [ 1 2 ]
Thu, Jan 6, 2011 at 3:25:03 PM
18
Custom Locations for Sun Studies - RA2009
Wed, May 21, 2008 at 5:56:25 AM
Adding custom locations for sun studies
Wed, Feb 25, 2009 at 9:41:00 PM
Firms with several offices in different locations
Thu, Oct 11, 2007 at 8:00:02 PM
Page generation time: 1.8636
