80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Revit Structure 2008 and NVIDA card settings?
Thu, May 1, 2008 at 4:13:12 AM | Revit Structure 2008 and NVIDA card settings?
clarkrob
I have the following settings set up for revit.exe (Structural 2008 version) and wondered if there is anything we need to address? We have several workstations.
We have the NVIDIA Quadro FX 570 (256mb). Comp is a 6300 processor with 3gb RAM. We also use Dual Screen.
Thank you for all your help
Anisotropic filtering - use global setting (off)Antialiasing - gamma correction - use global setting (off)Antialisasing - mode - use global setting (off)Antialiasing - setting - use global setting (none)Antialisaing - transparency - use global setting (off)Buffer-flipping mode - use global setting Conformant texture clamp - Use OpenGL specificationEnable overlay - Use global setting (off)Error repotring - use global setting (off)Exported pixel types - use global setting (colour indexed overlay 8bpp)Extension limit - use global setting (off)Masimise texture memory - use global setting (off)Multi-display/mixed-GPU acceleration - Use global setting (multiple display performance mode)Stereo - display mode - Use global setting (use on-board DIN connector)Stereo - enable - use global setting (off)Stereo - swap eyes (use global setting (off)Threaded optimisation (use global setting (auto)Triple buffering - use global setting (off)Unified back/depth buffer - use global setting (on)Vertical sync - use global setting (force off)
Structure Suite 2008
Tue, Apr 17, 2007 at 3:19:53 PM
Graphics Card Help!!!
Thu, Jun 9, 2011 at 1:48:48 PM
Project Browser - Revit Structure 2008
Tue, Jan 22, 2008 at 9:19:04 AM
Modyfing columns in Revit Structure
Thu, Nov 1, 2007 at 12:55:54 PM
7600 GT GRAPHICS CARD COLOUR PROB'S IN REVIT
Wed, May 7, 2008 at 11:34:39 PM
Page generation time: 3.0956
