32 Users Online (31 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Can we set our own constraints and if yes how?
Tue, Mar 29, 2005 at 7:09:27 AM | Can we set our own constraints and if yes how?
Owjan
Hi! Can you show me how to setup integers so i can have two elements occupying the same space in a family however they can't both be visible at the same time? Regards Owjan
Wed, Mar 30, 2005 at 3:37:23 AM | RE: Can we set our own constraints and if yes how?
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
Yes, you can set your own constraints. If u send send some image(what exactly u want) I can help u. regards Pavan
Wed, Mar 30, 2005 at 5:15:01 PM | RE: Can we set our own constraints and if yes how?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If you are using Revit 7.0, it is quite simple using the new <family type> parameter and nested families. The two elements need to have the same origin point and defined in the same manner. In your family types-->add Parameter-->Select the type to be family type-->Then select the correct category of the nested family. Name and group where you want. Then select the element-->Properties-->at the bottom select label and change it to your newly created parameter. You can now select between the two different elements...
Thu, Mar 31, 2005 at 2:05:51 AM | RE: Can we set our own constraints and if yes how?
Owjan
Hello mr Spot I send you a little more information and elucidation on what I mean and my problems. I want to be able to chose between to have threshold or not plus which type of threshold I want to have. Look at the attached file. Furthermore here's some questions. How and where do I create these new elementens? Are there own/separate families or made in the same family? Thank you for your help /Owjan
Thu, Mar 31, 2005 at 2:49:51 AM | RE: Can we set our own constraints and if yes how?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Here is an example door family where i've used this tool to make door handles interchangeable as well as turn off there visibilty. See if you can break it down to work out how to do it. Let me know how you go.
Thu, Mar 31, 2005 at 3:48:30 AM | RE: Can we set our own constraints and if yes how?
Owjan
Sorry! I can not change dorr handels!!??? I can not chose any other handle in "Handle Type" . What is it that I do wrong? /Owjan
Thu, Mar 31, 2005 at 8:15:08 AM | RE: Can we set our own constraints and if yes how?
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
First open the door family, then go for solid>>>extrusion(in 3d view). Select pick a plane and select the inner side of the door. Then go to left or right elevation (depends which side u have picked the plane). Draw the profile of your threshold. Give the extrusion thickness to some 1'. Then go to exterior view. Align your threshold to the other inner end of the door and lock it. Load it into ur project. If u increase the width the door the threshold automatically increases. Regards Pavan
Thu, Mar 31, 2005 at 9:06:01 AM | RE: Can we set our own constraints and if yes how?
Owjan
I am not certainly if your last insert/answer was meant for me. I have no problems with that draw in threshold, but i'd like to swap them depending of the door. /Owjan
Setting Default Wall Constraints
Fri, Jan 5, 2007 at 2:45:05 PM
Wed, Mar 16, 2005 at 7:50:00 AM
Finding my height constraints.
Thu, Apr 15, 2010 at 1:21:00 PM
Constraints Are Not Satisfied when opening file - Revit Architecture 2008
Wed, Aug 27, 2008 at 9:46:30 AM
Remove Constraints from Deleted Objects
Tue, Feb 26, 2008 at 4:44:57 PM
Page generation time: 0.7360
