95 Users Online (93 Members):
Forums >> Revit Building >> Technical Support >> import lineweights
31 Posts No Rating |
In my Revit model I have created several different lineweights (heavy, medium, light, ect.). Can I import these lineweights I created into my titleblock family? I have tried copying and pasting… that does not work. thanks
![3 Stars: 2 Votes](/images/stars_3.gif) |
Have the titleblock open as well as the file you want the linetypes from. While in the titleblock, goto File>Transfer Project Standards and make sure Line Styles in chosen. Hit OK. Your Lines are in your titleblock
That is what I was looking for. However when I click on the line I want to change and go to the line type pull down the new lines are not there… but when I go to Settings>Line Styles and expand the lines category the imported lines show up there. Seems like the lines are in the drawing I just can’t use them. Thanks for your help.
I see your problem now. When in titleblock families, you are really drawing lines as object styles. I don't think you will be able to use those lineweights that you created in the project. To create new linewights you will have to create new objects line types. This can be done in Settings>Object Styles.
imported dwg lineweights, linetypes |
Fri, Aug 10, 2007 at 9:22:53 AM
Import line weights from DWG? |
Wed, May 9, 2007 at 11:27:58 AM
Looking For Easy Way to Control Lineweights When Linking DWG Files |
Fri, Jan 18, 2008 at 3:17:58 PM
import lineweights into new family |
Fri, Feb 18, 2005 at 9:53:54 AM
Lineweights Issue |
Thu, Nov 17, 2005 at 6:05:35 PM
Members: | 2016995 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
