26 Users Online (25 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Workflow & Implementation >> Hardware >> Quad processors
Tue, Apr 29, 2008 at 3:30:43 PM | Quad processors
MarauderX
MarauderX Avatar
So I'm sitting on a machine with quad processors and Revit only uses 1 of them.  Any means to bypass & optimize to make the program scream?
Tue, Apr 29, 2008 at 4:25:42 PM | Quad processors
lunchtrayrider
3.5 Stars: 7 Votes
no?
I like scooters. and motorcycles.
Tue, Apr 29, 2008 at 4:31:02 PM | Quad processors
TJKENNEDY
3 Stars: 2 Votes
No, but you can make everything else NOT use one of the cores and isolate Revit to that one. I have a coworker who does that with some success.
Tue, Apr 29, 2008 at 4:46:47 PM | Quad processors
4 Stars: 201 Votes
yes, i use "SMP SEESAW" to isolate Revit in CORE 1 and the rest go to the other Core, turn Revit faster...
Tue, Apr 29, 2008 at 4:51:45 PM | Quad processors
lunchtrayrider
3.5 Stars: 7 Votes
can't you just do that in the task manager?
Tue, Apr 29, 2008 at 5:26:11 PM | lunchtrayrider
TJKENNEDY
3 Stars: 2 Votes
Quoting lunchtrayrider from 2008-04-29 16:51:45
"can't you just do that in the task manager?"
You can, but that gets reset every time you reboot your computer. I think the other programs you can use to do it will keep those settings.
Tue, Apr 29, 2008 at 5:37:46 PM | Quad processors
lunchtrayrider
3.5 Stars: 7 Votes
Thats a really good point.
Wed, Apr 30, 2008 at 9:17:08 AM | Quad processors
MarauderX
MarauderX Avatar
Yeah, I have it set for one of four dedicated to Revit, using the others for the system & other programs, but it seems silly, as I'm hitting any of the others at a max of 50% while Revit is bearing down 100% on a single one.  I'd like to bully Revit around with all 4 if possible.
Wed, Apr 30, 2008 at 12:18:20 PM | Quad processors
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
someone correct me if i am wrong but revit is not a 64 bit multitreading program yet, therefore, even when you would spread it over 4 processors it will only use 25 to 50 of the speed. Autodesk has promised that revit will be able to do this midway through the year.
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Wed, Apr 30, 2008 at 12:52:28 PM | Quad processors
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
I have dual quad cores and Revit uses 100% all my processor power to render. not really sure what else in the world could use that much processor power.
Wed, Apr 30, 2008 at 2:25:48 PM | Quad processors
#11
lunchtrayrider
3.5 Stars: 7 Votes
alabaster-
  can you do a screen shot of the task manager showing the 8 cores pegged while rendering in revit?  i'd like to show some people at work.
Wed, Apr 30, 2008 at 8:55:02 PM | Quad processors
#12
Eddieboarder91
4 Stars: 8 Votes
seconded.
Thu, May 1, 2008 at 8:17:35 AM | Quad processors
#13
MarauderX
MarauderX Avatar
Rock on, I'd love to get all four of these hopping...
Is there a patch/program that could do the same for me?  It seems that the folks at Revit aren't bothering to streamline with such noodly things.
Thu, May 1, 2008 at 8:45:43 AM | Quad processors
#14
3.5 Stars: 393 Votes
I would like to see how you use the task manager to isolate REVIT to one core and push everthing else off it.
Thu, May 1, 2008 at 10:18:32 AM | WWHub
#15
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting WWHub from 2008-05-01 08:45:43
"I would like to see how you use the task manager to isolate REVIT to one core and push everthing else off it."
WWHUB, beaware as TJKENNEDY said, once you re-boot, the config will be lost.
Edited on: Thu, May 1, 2008 at 11:20:36 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
QUAD PROCESSORS
Tue, Jul 17, 2007 at 8:52:39 PM
Intel Quad Core 2
Fri, Oct 27, 2006 at 4:51:27 AM
Horsepower
Wed, Oct 8, 2008 at 12:12:40 PM
Question on Revit Rendering in Quad Core Computer
Wed, Jun 10, 2009 at 11:38:38 AM
Revit and Multi-Cores / Multi-Processors
Wed, Nov 22, 2006 at 4:39:43 PM
Page generation time: 0.2355
