59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Change Leader line weight
Tue, Apr 29, 2008 at 1:21:04 PM | Change Leader line weight
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Hello there,
 simple question, how do I change the line weight in my leaders?  If I go to arrowheads in settings>>annotations... then the option to change the line weight is greyed out.
 thanks,
lorne
Denver, CO
Revit Architecture
Tue, Apr 29, 2008 at 1:30:00 PM | Change Leader line weight
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
For text objects you have to select a piece of text and go to Properties-->Edit/New. You can change the lineweight there. For tags and symbols the lineweight is controled in the Object Styles box under the category for each tag type.
Heavy Weight Leader Arrows
Fri, Jan 20, 2017 at 3:33:11 PM
Impossible to change ceiling pattern line weight
Tue, Jan 22, 2013 at 11:03:23 AM
change line weight in a family
Sat, Jul 3, 2010 at 5:12:25 PM
Line Type Weight Will Not Change, Overrides Set Will Not Show [ 1 2 ]
Sun, Dec 13, 2020 at 11:51:32 AM
16
Dimension Line Weight
Fri, Oct 7, 2016 at 1:32:52 PM
Page generation time: 0.8325
