118 Users Online (117 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Mitering Sloped Floors?
Tue, Apr 29, 2008 at 11:44:52 AM | Mitering Sloped Floors?
rmaciel
How to miter a sloped floor with a horizontal floor?
Thu, May 1, 2008 at 1:44:56 PM | Mitering Sloped Floors?
LIZARD2806
3.5 Stars: 7 Votes
I assume you are on RAC2008......
Draw the outline of the whole floor and use the floor slope tool.
If you don;t know what that is, draw the outline of the floor (including the sloped area) so it is all one hieght, click finish.  Then left click on the floor and you will get some editing options for the floor.  Help menu can explain further.
If you are trying to accomplish something else, you can join the floors together using the join command.
**Using Revit Architecture 2009, 2011, and 2012**
Fri, May 2, 2008 at 12:04:51 AM | Mitering Sloped Floors?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Just reiterating what Lizard said.
Do it all as one floor and use the point edit tool to do the slope section rather than a slope arrow.
Regards,
Chris.
Fri, May 2, 2008 at 10:54:32 AM | Mitering Sloped Floors?
rmaciel
Thanks, Lizard, Chris
I asked the question because just mitering with the join tool and trim to a continuous thickness is unproportionally complex... Using the editing tool to aggegate the two slabs in one is the way to go.
Thanks for taking time to provide this basic still very useful tip.
Ricardo
Wed, Mar 31, 2010 at 3:19:23 PM | Mitering Sloped Floors?
lalaindahouse
After you add a point for a slope, is there a way to undo that point, without having to start all over by resetting shape?
Wed, Mar 31, 2010 at 3:31:53 PM | Mitering Sloped Floors?
LIZARD2806
3.5 Stars: 7 Votes
If I am understanding the question, it is quite simple.
Click on the Select and Modify button on the options bar, right click on the point you want to delete and there is an option in the pop up menu to delete it.
Thu, Apr 1, 2010 at 6:14:41 AM | Mitering Sloped Floors?
lalaindahouse
thanks!!!!
detail lines on sloped floors
Tue, Jan 24, 2012 at 4:00:04 PM
14
Sloped railing on a Floor
Fri, Jul 2, 2010 at 11:32:10 AM
sloped floors
Thu, Jan 27, 2011 at 11:52:11 AM
Mitering curtain wall panels
Wed, Dec 26, 2007 at 9:11:55 AM
mitering gutters
Tue, May 2, 2006 at 8:59:03 AM
Page generation time: 0.5396
