103 Users Online (101 Members):
Forums >> Revit Building >> Technical Support >> EXCISTING BUILDING FILE AND NEW BUILDING FILE, HOW TO MERGE P.E. ELEVATIONS?
135 Posts No Rating |
hI ALL, I have an excisting model and a new building model, but in the new building model I created sheets, how could I implement an elevation form the excisiting model [drawing sheet] into the new building model! somehow revit doesn't allow sheets with elevations based on a model!! is there a way? i tried to export the elevation as a file, but it wont be merged on a drawing sheet
revit says, it cannot merge drawing sheets or view based on model views?? is there a way to convert this view to a impartable, mergeable format, like only 2d elements? R
Ok yes, create an image from the excisting elevation and insert that in the drawing sheet? is this the way??
Moving a building into another file |
Mon, May 7, 2018 at 8:29:26 AM
need an exterior view of the building in a DXF file. |
Mon, Apr 23, 2012 at 9:12:38 AM
Managing sheets and links |
Fri, Feb 6, 2009 at 7:03:06 PM
One File or Linked Files |
Wed, Apr 20, 2011 at 6:35:11 AM
Building Levels Vs Grade Levels |
Fri, Jan 14, 2011 at 10:32:00 AM
Members: | 2016995 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
