81 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Edit Families Within A Project
Tue, Apr 29, 2008 at 6:03:12 AM | Edit Families Within A Project
R7oky
I have just upgraded to revit 2009 i have some families within the current project that i wish to edit, however unlike 2008 once you had selected a family you had the option to edit family and it would open it up for editing and then save back into project, this option seems to have gone in 2009 how is possible to edit families that are currently within my project.
Thanks
Thu, May 1, 2008 at 1:49:12 PM | Edit Families Within A Project
LIZARD2806
3.5 Stars: 7 Votes
What part of the process are you missing?  I just imported a family into 2009, and everything appears to function properly....Have you tried doing it with another (different) family?
**Using Revit Architecture 2009, 2011, and 2012**
Thu, May 1, 2008 at 3:46:27 PM | Edit Families Within A Project
mhans
3 Stars: 10 Votes
Hi,
I think you still have the Edit Family button once you tag a family. Go back to your model and make sure you are tagging a family and not a group or you are not trying to edit a family in perspective mode.
Mhans
Motto: "No Post left behind"
Thu, May 1, 2008 at 11:48:38 PM | Edit Families Within A Project
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Families that were created pre-version 5.0 I believe do not have this functionality.  Unless its changed now to be a set number of releases behind the current lease before the edit family option disables...
Regards,
Chris.
Resident Profiles within the project...cant locate and edit them
Thu, Jun 23, 2011 at 7:01:36 AM
Edit Default Families
Sun, Jan 24, 2010 at 8:23:42 AM
Crash when trying to move/delete/edit families
Fri, Apr 6, 2018 at 2:38:07 PM
Cannot Edit Label After Inserting into Project
Fri, Sep 14, 2012 at 7:07:14 PM
revit 2010 edit families
Wed, Nov 23, 2011 at 10:48:33 AM
Page generation time: 3.1049
