73 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Is There a way to Automate Quantities for Each Door Type in a Door Schedule ??
Mon, Apr 28, 2008 at 4:55:26 PM | Is There a way to Automate Quantities for Each Door Type in a Door Schedule ??
pamoroso
pamoroso Avatar
4 Stars: 4 Votes
Is there a way to make Revit 2008 automate the total quantity for each door type in a door schedule instead of a grand total? I know I can create a new field and enter the quantity manually but I want to avoid this.
Thanks!
Edited on: Mon, Apr 28, 2008 at 4:56:42 PM
Mon, Apr 28, 2008 at 5:35:26 PM | Is There a way to Automate Quantities for Each Door Type in a Door Schedule ??
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
I think what you are looking for is the count parameter that you add to the schedule. In order to get this to work properly you have to add the field COUNT. Then go over to the Sorting/Grouping tab and sort by what you want. I like to sort by family. Make sure you uncheck the itemize every instance check box at the bottom of the sorting/grouping dialog. Then go over to the formatting tab and select count and check the box for calculate totals.
HTH
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Mon, Apr 28, 2008 at 6:04:03 PM | Is There a way to Automate Quantities for Each Door Type in a Door Schedule ??
pamoroso
pamoroso Avatar
4 Stars: 4 Votes
Thanks that did it! =)
Mon, Apr 28, 2008 at 7:00:51 PM | Is There a way to Automate Quantities for Each Door Type in a Door Schedule ??
brettgoodchild
4 Stars: 17 Votes
Glad that worked out for you!
                             ~ Abraham Lincoln
Door tags and Door Type ID
Wed, Jul 10, 2013 at 1:40:26 PM
Customized Door Schedule Needs Help
Thu, Aug 25, 2011 at 5:53:10 PM
Door Tag Parameter-Need it to be the door opening number, not the door type.....
Thu, May 7, 2009 at 4:09:40 PM
Door Schedule
Fri, Aug 17, 2012 at 7:07:51 AM
Same Door Type, Different Frame Type
Thu, Jul 24, 2008 at 3:16:27 PM
Page generation time: 1.0107
