44 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> Rendering Custom Materials
8 Posts No Rating |
Trying to render a wood siding on the exterior facade. I am using Revit Architecture 2008 and rendering from a camera. When the custom material is applied and rendered, the way that it is mapped does not look like wood because it is repeated exactly the same and never mirrored. Are there settings to adjust the tiling or repeated mapping of a material on a surface? Thanks. Sean
you can control your tiling materials, go to settings, materials, pick in the material you want, edit, and then change the "X" and "Y" value... save with other name...
8 Posts No Rating |
Thanks I will continue to "tinker" with these settings.
Revit Custom Materials Rendering Objects invisble |
Mon, Mar 14, 2011 at 10:42:55 AM
13
Custom Materials Rendering Black |
Tue, Jul 13, 2010 at 5:42:22 PM
additional rendering paths |
Mon, Apr 13, 2009 at 2:13:42 AM
Rendering Materials |
Wed, Sep 13, 2006 at 1:13:06 PM
Revit materials missing at rendering [ 1 2 ] |
Tue, Jun 14, 2011 at 11:24:21 PM
22
Members: | 2042244 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
