82 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Column Grid Question in Revit 2008
Sat, Apr 26, 2008 at 4:56:38 PM | Column Grid Question in Revit 2008
CCABob
I'm noticing a problem and curious if there's something that can be done or if I'm in deep trouble.  It appears to me that when doing an elevation that is not perpendicular to the grids, the grids don't appear.  I have a building that has two "wings, one that is 15 degrees different than the other.  If I do an exterior elevation, the elevation will show the grids running perpendicular to that elevation, once I get to the "skewed" portion of the elevation those column grids do not show.  The "skewed" grids in the first example will show if I create an elevation perpendicular to that building angle and the other grids won't.  This also happens for interior elevations that aren't perpendicular to the grids.  Any insight would be greatly appreciated.
Column Grid Text
Tue, Dec 11, 2007 at 9:33:36 AM
Column Grid Line Weight
Sun, Aug 13, 2017 at 3:05:53 AM
column grid visibility
Wed, Nov 15, 2006 at 3:43:13 PM
Column to Grid
Tue, Sep 8, 2009 at 4:09:31 PM
Column grid text too wide to fit in bubble
Thu, Jul 1, 2010 at 8:32:06 AM
Page generation time: 2.2455
